JJB*
Flight distance : 12225059 ft
Mzp Posted at 3-27 08:10
Hi Franky,
It is not as much for filming , but for something else. During RTH my drone sometimes goes up higher than 120 meters (my RTH height), it might go up to 220 meters sometimes (maybe because it thinks it needs to avoid a bridge). When this happens and I see the bridge is not on the course , I try to manually lower it back to 120 meters or lower, but it does not seem to respond to commands to lower. I think it's because it's thinking it might need to go higher than 120 meters because it suspects it might need to go over the bridge (I have straight line RTH ). But the bridge is actually on the right and the drone won't be passing it. I get worried when my drone goes higher than 120 meters and I start to get AirSense warnings and try to get it to go lower, but it won't. That is basically the main reason for me wanting to be able to lower drone altitude during RTH or also raise altitude in case I see that I may need to avoid an obstacle or AirSense warning. Thank you for your input on this
Hi Mzp,
in a RTH climbs to the RTH height setting ofcourse, not higher. Only reason for getting higher is to avoid an obstacle close to your drone. OR when it sense an obstacle FALSE and bc of this starts to climb.
But this is easily spotted in your flightlog.
So if you like, upload your log using : https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here.
If it does climb above the setting, and you are in control, just cancel the RTH and fly home manually (as the heading is already correct, just fwd and down stick....)
In RTH the OA is ON, even if the OA is set to OFF in the menu.
cheers
JJB |
