New DJI RC Motion 2 Firmware Released (12/21/2023)
12
8343 46 2023-3-28
fans8cf3c1fe
Austria
same here dji viretual fligh app dont work
2023-5-24
Johmic
Flight distance : 196955 ft
Greece
Does the new firmware resolve the FN dial compatibility issue  with the Goggles V2 ???
2023-9-6
djiuser_yNzLmJcl1GoD
Totally lost signal of my drone while flying. This new software was updated today, was going just fine, after 5 minutes, complete signal loss and no RTH.
Anyone had a similar issue after update ? This is motion controller v2.
2023-9-11
DJI Gamora
Johmic Posted at 9-6 01:08
Hi, Johmic. We're sorry for the inconvenience. Currently, when used with DJI FPV Goggles V2, DJI RC Motion 2 does not support adjusting camera parameters or the gimbal tilt through the FN dial.
2023-9-17
DJI Gamora
djiuser_yNzLmJcl1GoD Posted at 9-11 17:32
Hi, djiuser_yNzLmJcl1GoD. Thank you for reaching out. Please confirm/try the following steps below:
1. Confirm whether the flight distance is within the maximum transmission distance range, if it exceeds the maximum range, it may be abnormal or disconnected long-distance signal transmission;
Note:
The maximum transmission distance of DJI FPV in a non-interference and unobstructed environment is 10 km (FCC) /6 km (SRRC/CE).
2. Confirm that the aircraft, remote control, and goggle's firmware versions are all the latest versions. If not, please update them first.
3. Please check whether the flight environment is open and clear, and whether there is any interference (such as a communication base station, a transmission line tower, and so on).  For Avata, please make sure that the image transmission band is set to auto mode or 40 MHz to obtain the best image transmission signal.
4. Check the position of the remote controller. Point the remote control in the direction of the aircraft to reduce the communication distance. Please make sure the goggle antenna is well mounted and unfolded, and check whether the goggles antenna is damaged. If it is damaged, it needs to be replaced.
5. Is there any obstacle between the remote controller and the aircraft, and are you flying with your back to the aircraft? (Avoid shortening the communication distance due to obstruction)
The influence of obstruction on the image transmission signal is similar to that of other wireless signals. For example, the signal of domestic routers will be greatly weakened after passing through a wall. The radio signal will attenuate during airborne transmission. A common roadside camphor tree crown can attenuate the signal by about half of the image transmission distance. Dense trees or a reinforced concrete wall can attenuate the signal by about 1/32 of the image transmission distance. Hence, please check the surrounding flight environment to eliminate signal attenuation due to blockage as much as possible.
2023-9-17
Fred Fred Fred
Flight distance : 4512966 ft
Thank you Dji
2023-9-23
DJI Tony
We are glad we have reached your satisfaction. We value our customer's sincere feedback and use that to continue optimizing our services and products. We appreciate your valued support. Have a great day ahead.
2023-10-2
12
