osmo action 3 voice issue
1670 14 2023-3-28
TravelFit
India
Purchased action 3 for motovlogging, alongwoth cynoca adaptor and rode lavilier go mic, but facing issue ....wind blast is high and outer noise is more.
2023-3-28
lutzmix
cynova adapter dont worked with the OA3
the Adapter is for the first Osmo Aktion
2023-3-29
TravelFit
India
Which Adaptor is suggested ?
Boya by k4 is good ?
2023-3-29
lutzmix
https://forum.dji.com/thread-280749-1-1.html
2023-3-29
TravelFit
India
couldn't get it
2023-3-29
lutzmix
side2
best cheap mics
2023-3-29
TravelFit
India
what about adaptor...? which adaptor...i do motovlogging
2023-3-29
lutzmix
https://forum.dji.com/forum.php?mod=viewthread&tid=280749&extra=page%3D1%26filter%3Dtypeid%26typeid%3D781%26typeid%3D781
boya k4
boya k2
samsung  trrs
read it all
not all adapter usbc to 3,5mm will work
yt is your friend
example
rode lavallier go is to sensitive, by a cheap 2-10 bugs lavallier mic
2023-3-29
Fishycomics
Thank you for asking to be a friend on DJI. Please do take the time to makesure you buy the right accessories  for the Action 3.
CYNOVA like said is only and only for the decommissioned Osmo Action. the Action 3 doe not require a   adapter for wireless usb C mic and USB C type  wired mics. If you are going the route of TRS mics then you will require a OTG microphone cable, while    Knock off  cables for all phones will most fail when they cost a few dollars.  the found ones are  boya like noted.  DJI has  relied on 3rd party people to  make a product for them and yet no one  in DJI will offer any insight or help on the cables that work.
to make   your product to work on motovlogging is best to  explain with photos then asking and what you want and how,
ALso there are topics here with issues about motovloggin, with a mic.
good luck
2023-3-29
4wd
Flight distance : 545817 ft
The Boya K4 is the safest bet for most lavalier mics, it seems hard to find I did get one from ALiExpress.
Alternatively you can get microphones plug direct into USB-C they are widely sold to use with phones
Unfortunately they are more complicated than they appear and some work well, some don't work properly and some don't work at all.
The DJI mic is possibly most versatile option but quite expensive - however very useful for other video audio too.
2023-3-29
TravelFit
India
well I am going try combination of rode lavalier go mic, sc4 trs to trrs convertor and 3.5mm usb c.
2023-3-29
TravelFit
India
Can anyone tell at what gain should I adjust for better voice quality -  +5db, 0db, -12db ?
I am using rode Lavalier mic.
2023-4-5
Fishycomics
watch the Mic on the rear and front you do not want to go in the Red  -12Db  Rode tends to go o the high side so lower it down, suggest  to  do your own testing
start at 0 and say test 1 , 2, 3, 0 db, and  go down, repeat till you  get the best results  when playing back.
2023-4-5
johansenfoto
Flight distance : 1180089 ft
Norway
With Røde I think -12db would be best choice, is what I use with Boya
2023-4-5
TravelFit
India
johansenfoto Posted at 4-5 02:58
there is shortage of boya mic here in india, I am using rode sc4 connector + sumsung usb + rode mic and i have set 0db, i am getting better voice quality than -12db
can you share your video link
2023-4-5
