LV_Forestry
Flight distance : 4726654 ft
Latvia
Labroides Posted at 3-29 13:51
Why recalibrate the compass?
If your compass wasn't properly calibrated, you wouldn't be able to fly normally?
When people suggest recalibrating the compass or recalibrating every thing, they usually have no idea what caused a problem or what might fix it. It is a generic procedure. At least it's done, and maybe that's enough to solve the problem. Anyway you have to do it because when contacting the support it is the first question they will ask.
I already had a similar problem, it was not the gimbal but the whole drone which rotates on yaw. The trouble came from the radio joystick. Nothing to do with the compass.
But on the support chat the first question was did you crash the drone? the second have you tried to calibrate IMU and compass?
So, you can answer firmly that yes it is done and that does not change anything. Then you go to the after-sales service stage.
It's the logic of DJI, employees have a script they follow it. You know it as well as I do from reading the mods' replies on the forum.
