DJ DJ
hurtighansen1 Posted at 4-2 23:09
think, as i do, find trs way to sensitive. And trrs kind of perfekt for action cam aka oa3
i use trs if i need to catch a mouse eating, but not out in wind so on.
If you can't live with that trrs mono, you need to think, extern recording.
If the pin layout of your adapter fits the layout of your microphone, no problem, everything is right. If it does not, the sound is possibly crappy and distorted, or just low-ouptput, depending on the microphone you use.
There is no difference in sensitivity for trs and trrs, just "right wiring" where the contacts fit the right couterpart, or "wrong wiring", where they don't. The outcome is simply a matter of luck with trrs adapters, as there is no standard and most of the time no description, what pin layout an adapter uses. Just because one type is used most of the time, it is no guarantee, you get the right one.My point is - if there are different options for adapters, use the right one. Why do you need user feedback for that? Why does DJI not provide a failsafe adapter that responds to the gain control? Just because it is an action cam, I don't accept crappy audio when it is very easy to give a suitable recommendation with the same efford.
I have no problem with my usc-c to trrs adapters (I uses the KIWIbird adapter and a UGreen angled one) but my microphone has a dedicated trs-to-trrs cable that luckily uses the same pin layout. Gain control does not work, though - refer for the other thread for this.
I have another trrs-to-trs adapter, that uses another pin layot for an old Sony-Ericsson phone, that would not work, so if for any reason I get a usb-to-trrs-adapter with that layout, I waste my money...
The best solution is a usb-c microphone with it's own gain control, but that was not, what the thread opener asked for...
Most of the time, I use no external microphone because it is an action cam. But when I do, it is no excuse to arrange with crappy incompatible stuff just because of bad documentation...
