This DJI Mini 3 Pro beginners video will show you if you need an ND filter to create motion blur in your footage by adapting the 180-degree rule. You will learn that it means less than what you have been told, and my point is there are many other areas where you could improve your skills and get much better results without trying to hit a shutter speed that is double the frame rate.
Watch this and tell me if using ND filters is worth the hassle:
My recommendation: Don't start by wasting money on ND filters; this applies to any fixed aperture DJI drone, such as the DJI Mini 3 series or DJI Mini 2.
Great comparison video Henrik. I normally leave an ND16 on just as a protection for the camera lens. I keep the histogram on for exposure consistency but probably don't need to do this because Auto should compensate.
DowntownRDB Posted at 3-30 09:23
As long as you aren't right on the ground, recording video and moving very abruptly / and or quickly it matters very little as you allude to. If you are flying very high from the terrain e.g. say over 50 metres, the difference isn't really noticeable as to motion blur in video apart from maybe to a very seasoned video geek. As you explain, on a drone like this with a fixed aperture it is a bit of a faff using them when the light changes. Since I only do photography for most of the time, it matters even less...
ND filters will always have a place in photography and videography, whether you need them or not, thats the users choice, and also dependant on the shots required.
