Sean-bumble-bee
Flight distance : 15997 ft
Bashy Posted at 4-12 23:08
I was wondering if you thought that it reacted via the OA.
I initially thought about the taping up of the bottom sensors and was about to type it but then I also thought that that wouldnt be any good as it wouldnt be recreating the decent to see if the close quarters to the wall was the cause.
No, a pure guess, though it seems to be a bit logical to me, is that the initial vertical portion of the bounce/s might be a belated Landing Protection reaction, same as you get if you put your hand under the sensors, coupled with continued downstick by the OP, I'll need to check that later, on the wrong device at the moment.
With regards to OA I have noticed that the manual details how OA will work during RTH climb to height (brake and move horizontally away from the object) and during the horizontal flight home ( brake and climb). It also makes mention of the drone climbing during the horizontal flight home if it senses something underneath the drone. BUT, that I can see, it makes no mention of what happens if the drone senses an object in front of or behind the drone during the descent, leaving me puzzled as to whether or not it reacts to such an object. I am also curious as to whether or not the response to something close to the bottom of the drone during the horizontal flight home is anything more than a "hand under the drone" response or a just 'marketing ploy' to "talk up" the "hand under the drone thing".
Then there is the section on APAS which baffles me lol and makes me wonder if it is duplication of stuff already described elsewhere in the manual. From memory I had the same thoughts about the APAS section in the Mavic 2 manual.
I think if I owned a Mini 3 Pro there would be a lot of experimental flights, to clarify my understanding of the manual, before I sent it out on a proper flight.
Given the manual's reference to the drone moving to avoid an obstacle during the climb to RTH height, I am left wondering if it does the same thing during ANY climb and if so could the forward movement during the bouncing be a response, during each upward portion of the 'bounces' to the low wall behind the drone.
I think it would be a really good idea, but unlikely to happen, if one of the DJI engineers weighed into this thread and explained what we are seeing, this thread seems to have raised an awful lot of questions.
