Server error: Wait a moment and try again(Code:0x1151009fffff)
3703 20 3-30 16:42
SkipMc
Flight distance : 233166 ft
Thailand
Hello, I cannot update to the latest version as all updates are blocked on my RC with the error: "Server error: Wait a moment and try again(Code:0x1151009fffff)" - I have logged out and back into my DJI profile, have rebooted the RC remote and Mini 3 Pro drone, and also waited 45 minutes, and the error happens every time I try to update via the Profile section or the Settings-About section of the RC UI. Please advise. Thank you.
3-30 16:42
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to install the firmware via DJI Assistant 2 using your computer? You may download the software using the link below. Please let us know if you experience any issues with the software. Thank you for your understanding and support.
https://www.dji.com/downloads/so ... sumer-drones-series
3-30 17:07
SkipMc
Thailand
Thank you, I tried that. It got to 87%, installed an update and rebooted the controller, but it's now stuck at 87% and my PC now says it no longer recognizes the USB device. And even worse, I can no longer see the drone from the Connection Guide screen on the remote.  Please advise.
3-30 18:32
SkipMc
Thailand
After unplugging the remote from USB, rebooting it, and rebooting the drone, all seems to work now, thank you!
3-30 18:42
pa01os
Flight distance : 1312579 ft
If anyone else gets this error check the time on the remote and if wrong, correct it, I had tried clearing the cache, logging out and back in again to my account on the remote, I even went as far as trying to configure my router to the default Google server addresses but simply correcting the time fixed the issue.
4-1 07:54
djiuser_4aDhMvBzEAWB
Flight distance : 46276 ft
I am having the exact same drama and unfortunatly dont have a PC for two weeks, tried all the above to no avail. Why is it never simple.
4-1 12:41
djiuser_f6YX51avOYhu
Flight distance : 48960 ft
Would like to update my remote controller but getting error?
4-1 14:26
Swipe down from the top of the screen, clcik the little cog in the top right corner, click system, reset options, then reset app prefereces.
If this doesnt work go back to the system menu, date and time, use network provided time and time zone.
4-1 23:57
df3966gmail.com
Flight distance : 504360 ft
pa01os Posted at 4-1 07:54
Great advice.  That’s precisely what the issue was that was giving me this error.  Set the date and time correctly and bingo back in action
4-2 05:15
fansf2f9b6ac
Flight distance : 873360 ft
Thank you!!! problem solved. I had the same issue, first changed the time zone and corrected the time and I was able to update to latest version.
4-2 21:22
bgreenstone
Flight distance : 709495 ft
None of this worked for me.  The time and time zone are correct on my controller yet I still just get that error message when I try to update.
4-7 08:49
DJI Tony
bgreenstone Posted at 4-7 08:49
Hi there. Thanks for reaching out, and we're sorry for the inconvenience. It is recommended to check the current network status and log in to the account to test again. You may also try updating the firmware using the DJI Assistant 2 (Consumer Drones Series). Please keep us updated.
4-8 21:56
djiuser_IpmoP11vcJ3U
Correcting the time did not work for me but I found that I was not logged into my profile. After logging in the problem was solved and I was able to update the drone.
4-15 00:23
fans386bfcae
Flight distance : 286250 ft
Correcting the time did not work also for me....  I am logged into my profile.  The problem for me hasn't been fixed and I I'm just not good at upgradingable to update the drone.
5-2 10:38
djiuser_CHyB1rm8yT8v
djiuser_4aDhMvBzEAWB Posted at 4-1 23:57
Thank you.
6-2 03:15
fans9f536d45
That worked! Time was off by a day.
7-2 05:15
djiuser_pwOENfNJbjmH
djiuser_f6YX51avOYhu Posted at 4-1 14:26
I couldn't update my dji pro 3for months I tried everything so I thought come ro find out I wasn't logged in on my controller signed in and it worked we are updated
8-9 16:12
djiuser_8CrAzjyVIh04
Flight distance : 520577 ft
I had the exact same issue (Code:0x1151009fffff) and updating the time by enabling "Use network-privided time" fixed my issue, Thank You very much
8-30 21:34
Drone Sketcher
Flight distance : 122241 ft
DJI Paladin Posted at 3-30 17:07
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
This is so bad that you have bricked the drones from connecting!!!
Then you ask us to download an app from an UNIDENTIFIED DEVELOPER!
That the mac refuses to install!
What is going on?
8-31 08:23
Drone Sketcher
Drone Sketcher Posted at 8-31 08:23
Then when figuring out how to get past the unidentified developer I get this.
8-31 08:27
DJI Paladin
Hi there. We do apologize for the trouble. If you download the software straight to our website, please follow the instructions below to install the software on your MAC:
To override the security settings and launch the app, please follow the steps below:
· Find the app to be launched in Mac “Finder”.
· Avoid using Launchpad to execute this operation. Launchpad is not allowed to access the Shortcut menus.
· Tap and hold the Control key and tap the app icon. Select “Open” from the shortcut menu.
· Tap “Open”.
· The app is now saved as an exception to your security settings, and you can open it in the future by double-clicking it, just as you can any authorized app.
9-1 18:39
