New Mini 2 Firmware 01.07.0200 Release
5027 29 3-31 03:27
B Master
Greece
New Mini 2 Firmware Release v01.07.0200 is out.
3-31 03:27
neoborg
Do you have any further information about this update? For example, what's new, changed, improved or made worse?
3-31 03:37
neoborg
Just a heads up to let others know that I think this fixes the free FCC hack that Android users have been using for a long time now.
I did also update DJI Fly to v1.9.9, so it might be that.
3-31 04:43
yogi053
Flight distance : 7813159 ft
Great! I just asked Dji to clarify Mini 2 firmware versions less than 24 hours ago and Dji Paladin said I was all up to date and now we have another update!
3-31 05:04
B Master
Greece
neoborg Posted at 3-31 04:43
The FCC hack still works perfect with the new firmware! Just test it.
3-31 05:23
djiuser_wvcdyFyC0lFA
Flight distance : 20951 ft
My controller turned off after the update and hasn't turned back on.
3-31 05:33
yogi053
Oh! oh! There's another thread on here somewhere about controllers dying (even from new) and not coming back on!
3-31 06:17
neoborg
B Master Posted at 3-31 05:23
Can you PM which one you are using? The one I use didn't appear to work, but I have read online of people having to try three times - but I think was a different hack to what I use.
3-31 06:28
Lton85
Flight distance : 836752 ft
Brazil
I would really like to see new features in the mini2
- AEB shot with +2 EV difference between shots
- Vertical panoramic shot
- Vertical video, making full use of the vertical sensor, (when making a horizontal 16:9 video, we already have a cut at the lower and upper ends,)
- point of interest ( POI )
3-31 06:30
neoborg
Just tried to apply the FCC patch again, but sadly it doesn't appear to having any effect any more.
Information about the drone's firmware update:
Information about the DJI Fly update:
Some basic information from DJI Fly v1.9.9 after updating:
Before applying the FCC patch:
After applying the FCC patch:
3-31 06:48
yogi053
neoborg, it looks like you are on FCC mode. The 90db line is below the 1km mark.
Are you sure you don't have the permanent hack?
3-31 07:09
blue_canyon21
Flight distance : 21862874 ft
Just updated and tested.
Took it a lot longer than usual to acquire a strong GPS signal but when it did, everything went well during the test flight.
3-31 07:12
yogi053
You MUST check your settings after ANY update. My RTH was set for 120metres. I've NEVER set it that high! Other settings changed as well. So check and reset them all to your satisfaction.
Just updated both of my mini 2s and all is well. (SO FAR)
3-31 07:13
neoborg
yogi053 Posted at 3-31 07:09
Not as far as I know, as, I use the "mavic air 2 fcc" (sic) app on Android.  But after seeing screnshots at https://greyarro.ws/ (I won't put a direct link to the page, in case it is removed or worse) I can see what you mean now.
When it actually stops raining (good old British weather!), I will see what happens.  I have a couple of things I need to test and this weather is stopping me.
3-31 07:22
DJI Tony
neoborg Posted at 3-31 03:37
Hi, neoborg. Thanks for reaching out. DJI Mini 2 just released a new firmware update (v01.07.0200). This added Reset All Settings and Clear All Data options. You may refer to the User Manual (page 36) for more details. Please reach us back should you have further concerns. Have a nice day!
3-31 23:45
DJI Tony
djiuser_wvcdyFyC0lFA Posted at 3-31 05:33
If it doesn't turn on at all, kindly try plugging it into a charger and check if it shows any signs of charging. If not, try replacing the charger. If it's the same, attempt to turn it on again by pressing the power button for one second, then again, hold to power the remote controller on. If the issue remains, kindly post a short video showing the issue for further checking. We appreciate your cooperation.
3-31 23:54
DJI Tony
Lton85 Posted at 3-31 06:30
Hi, Lton85. Thanks for reaching out. We appreciate your feedback. These are indeed useful functions and features. We will have them recorded and forwarded to our designated team for attention. All significant suggestions or requests will be implemented after the evaluation of the DJI Engineers. For the latest updates on DJI, please stay tuned to our DJI official website at www.dji.com. Thank you, and stay safe always.
3-31 23:55
pribeiro73
Flight distance : 1831677 ft
Portugal
When every new update is out POI is the first thing I go look if it was added. One of the features I miss most in Mini 2.
AEB with +2 EV difference would be nice too.
4-1 04:45
DJI Tony
pribeiro73 Posted at 4-1 04:45
Thanks for the added suggestions. This will be forwarded to our team as well. We appreciate your continued support and interest in DJI Products. Have a nice day!
4-1 23:49
carnelius
Fcc patch is not changing the graphic with the latest update. I have downgrade to the .100 version and its working perfect.
4-10 12:39
carnelius
carnelius Posted at 4-10 12:39
ANY HELP GUYS??? THE PATCH IS NOT WORING WITH THE .200 FIRMWARE IN MINI 3 (NO PRO).
WHY??? IT STRANGE, WITH .100 WORKS PERFECT.
4-10 14:45
gnanatheepan
Sri Lanka
I have same issue with my RC 231 / RC N1. Have you resolved it?
4-10 21:33
gnanatheepan
Sri Lanka
yogi053 Posted at 3-31 06:17
I'm facing this issue. Please somebody help me to fix it.
4-10 21:37
gnanatheepan
Sri Lanka
I have same issue as you have mentioned. Have you resolved this issue?
4-10 21:38
DJI Paladin
Flight distance : 318 ft
carnelius Posted at 4-10 14:45
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please provide us a video or screen recording showing the issue so we can check? Please keep us posted. Thank you.
4-24 01:14
DJI Paladin
gnanatheepan Posted at 4-10 21:38
Hi there. Can you please confirm if you still experience the said issue? Please let us know. Thank you.
4-24 01:17
clarencereed
Flight distance : 159521 ft
Just updated my mini 2 to latest firmware 01.07.0200, and DJI fly app to 1.9.9(752).   All good so far
4-26 03:43
axel12p
Greece
How did you downgraded to .0100? I tried to downgrade using DJI Assistant, but I can only find 01.06.0200 version. FCC Hack still doesn't work with this firmware version.
5-9 23:57
djiuser_0b8jYA3JdIzY
Flight distance : 174531 ft
HI ALL
AFTER NOT FLYING MY MINI 2 FOR OVER A YEAR DECIDE TO START AGAIN AND BIGEST MISTAKE I HAVE EVER DID IS INSTAL THIS FIRMWARE 01.07.0200. AND NOW MY DRONE LOOSING CONNECTION AT EVERY FLIGHT JUST 15-20 M AWAY DO NOT ASEND TO SAFE SET HIGHT AND JUST GO AND LAND AT HOME PONIT.  DID ALL WITH DRONE AND LAST 2 WEEKS EMAILS BACK AND FORWARD TO DJI WITH THIS PROBLEM. STILL NOT SORTED. HUNDREDS TIPS DONE MIU SET,  REINSTALL FLY APP YOU NAMED STILL NOTHING.
JUST TO ADD BEFORE UPDATE I CAN FLY NEAR MY ESTATE NOT EVEN ONE PROBLEM WITH CONNECTION EVER.  LET'S WAIT AND SEE ARE THE DJI WILL SORT THIS OUT.???,
5-17 05:23
DJI Tony
djiuser_0b8jYA3JdIzY Posted at 5-17 05:23
HI ALL
Hi there. We're sorry for the inconvenience this has caused you. Have you tried refreshing the firmware of the drone? And you mentioned you forwarded this concern to DJI, were you given a case/reference number we can check? Thank you.
5-17 09:05
