DJI Mic Receiver only works with Headphone plug ?! Not with the Out.
1811 7 2023-4-3
PadamPa
Greece
Hello,
I have a super weird problem:
Connected my camera (Sony Zv e10) to the receiver of the dji mic as usual and filmed all day.
At the end of the day I noticed that the last few videos have no sound (even though I did not change anything).
The following PROBLEM: The output from the receiver does not work anymore. Only the headset output. Means: If I connect my camera to the receiver and plug into the output comes NO sound. If I plug the cable into the headset output of the Dji receiver , I get a sound.
I have already updated everything, the microphone works fine, only I ask myself the question:
How can this be ? How can the output change overnight to the headphone output? Because now i cant use the Headphone output anymore.
As I said, I have already changed all the cables, made everything clean.
AND if i connect the cable very slow into the output it shows me the "sign" that the aux cable is not correct into the plug - so the connection is there...
Am really at a loss.
Has anyone ever had the problem?
2023-4-3
PadamPa
Greece
Nobody any idea?
2023-4-11
HGDC84
Finland
Have you done a firmware update recently? Did it go okay or did you experience some errors? That does sound like quite a weird occurrence. My DJI Mic didn't sometimes show up correctly with my Pocket 2, but it seems like I got it fixed by taking the plug out and connecting it in again (connected it through the Do-It-All Handle).
Also, does that only occur with the Sony and/or the audio cable, or does that happen with other cameras and devices and/or using the USB-C or Lightning adapters?
That sure seems mysterious, I hope you get it solved. Maybe somebody at DJI could give you a hand here?
2023-4-11
Spenn
dealing with this now?> ever get it fixed?
2024-2-12
djiuser_D0iXHMGAPvrE
I am experiencing the same issue now. Has anyone ever solved this yet?
2024-2-21
RoddyG2
Antigua and Barbuda
Same issue with Mic 2
2024-6-8
djiuser_RlScYYffZkdf
I have the same issue with the DJI Mic 2 headphone jack is fine but he output jack doesn't work at all
2024-8-2
fansa627722d
El Salvador
Experienced the same problem. DJI NOT answering. No videos on the internet about it either.
1-6 10:08
