JJB*
Flight distance : 12225059 ft
MoToad Posted at 5-3 08:08
I was able to get and view the flight logs per Labroides suggestion. All of them displayed P-GPS for the first couple of minutes and then, repeatedly P-GPS (bypass)((whatever that means)) the map showed the crazy course changes and the last one had the startpoint showing out over the water, which it was not. Seeing here there were very recent updates that, among other things, stated a few 'minor' bug fixes, I did the download and install. I'm glad my losing controller in mid flight was only minor. And here I thought I had something to worry about. lol. Anyhoo a sunrise flight this morn had everything working as it should and I even risked a 4km flight. It's fixed...I think. More filights, when I have the time, will tell. Thanks again for all your help.
Hi,
The FlyApp does not show P-GPS for a flightmode.
Phantom help CVS does show P-GPS ect.
P-GPS = N -mode with APAS Off.
P-GS (bypass) = N mode with the APAS set to Bypass
P-GPS (brake) = N mode with the APAS set to Brake
But not always does PH csv shows the correct P-GPS....
I always fly with a screen recording active, so you can check your log together with the screen recording.
Or use FRAP. (if you are a Windows user)
cheers
JJB |
