DJI Diana
Flight distance : 2408 ft
Exact Science Posted at 4-6 05:27
Yes I have insured I have the latest update before posting in the forum.
The assist sees the controller fine right away but never sees the Mavic Pro.
Hello. I'm sorry for the inconvenience caused. Please check whether the aircraft has a microSD card. If yes, remove the microSD card and try linking again. If unsuccessful in linking using the app, please try linking using combination buttons and check whether the linking is successful. The combination buttons for linking your aircraft, press and hold the C1 Button, C2 Button, and Record Button at the same time. Wait until you hear a quick single beep after an alternating double beep. Then, press the Shutter Button. Wait until you hear a pulsating beep sound from the remote controller and the screen displays Binding. Then, release the buttons.
If the issue persists, please send your aircraft and remote controller back to DJI for diagnosis. You can contact our relevant team thru this link https://www.dji.com/support for further assistance at the request to start a case and investigation on this incident. Thank you for your understanding. |
