FEATURE REQUEST - In-camera timecode synch
910 2 2023-4-6
Italo Grossi
Austria
Hello DJI team,
I have a feature request to make but not sure if it is technically possible.
If this feature can be implement it would be positive for the users, push more users to switch to yout system, and create a clear advantage over the competition!
Is it possible via a software update to turn the OA3 into a timecode generator which then can be used to synch other OA3 to it?
You can make this funcionality to be active only in between OA3 cameas. It wouldn't work if the user has a GoPro for instance.
In the last update you have already added the timecode option to the OA3 settings, however to synch multiple cames the users still need to buy a separate device(Tentacle sync for instance).
Instead of using a separate device, let 1 OA3 act as the Master Camera and any additional OA3 would be the Slaves of it synching to the master camera. The timecode transfer could be done be connecting the Master Camera to the slave camera directly via USB-C.
What you think?
2023-4-6
DJI Paladin
Flight distance : 318 ft
Thank you for your feedback. We really appreciate the time and effort you have invested in providing this suggestion to us. Your feedback will be definitely cascaded to the concerned team for further review. Thank you for your understanding and support.
2023-4-6
fans38e8f023
I'd like to upvote this feature request.
2023-8-22
