gil
Flight distance : 1379308 ft
Can you be a bit more specific about the twitching? Is this in still air while the Phantom is hovering? Have you had a few bumps, minor crashes and tip overs? That can affect both the motors and the props. A little bit of dirt in the motor could cause these symptoms. If you've done a full set of calibrations -- sticks, compass, IMU and it's still twitching I would try a new set of props next.
If you want the default setting just click the "default" button in the bottom right corner. |
