xSc00psx
Flight distance : 20338 ft
Sorry DAFlys, I misunderstood, I thought you meant in LightCut.
I have the new RC with the built in screen and did not need DJI Fly but I downloaded and tried anyway.
I alway have bluetooth on my Samsung Note 9 turned on and it found the drone but when I went to select it on the mobile a pop up says it cant connect check your mobile settings!
I turned the bluetooth off, restarted the DJI Fly app with the drone still in connection mode (blue flashing led'), turned the bluetooth back on and then Switch to QuickTransfere Modeswitch appeared on the DJI Fly app!
Allowing access to all the media to let me download and save to my mobile gallery.
I tried to connect LightCut again with the bluetooth off - Pressed connect within LightCut, it promts to turn bluetooth on mobile setting (Note: when it did find the drone, I did not press on the drone on the mobile settings) - went back into LightCut where it promted to connect, pressed it and weirdly enough, it connected to the drone - mind blown!!!
Tried to perma pair drone to phone but it was having none of it.
It's a faff and I'm baffeled by it, but after all that it worked !!!
Must be a bug that needs looking into, just a thought LightCut
Thanks DAFlys - I would not of thought of installing the DGI Fly app with having the new controller. |
