djiuser_nRg62gEQ6E45
Flight distance : 58258 ft
DJI Wanda Posted at 4-12 20:35
Hello, there. Sorry for the inconvenience. The Altitude zone notification is related with local regulation and fly safe, which act as a reminder. Detailed movements of the aircraft in different scenarios can be viewed here: https://fly-safe.dji.com/nfz-introduction In your case, you set the Max height to 20 m, the aircraft is subject the settings because it is less than the restricted height. Please pay attention to that and be careful about the flight environment when flying. Seeing that your drone crashed, we will recommend you send it back for repair. Here is the link:https://www.dji.com/support/repair?from=store_homepage
Thank you very much for your response. I already sent the Avata for servicing.
Mine was a simple suggestion for a possible improvement in the indications on the Goggle display. The possibility to move upwards the circle set by the Motion Controller without having the drone following it because max altitude reached (no matter which altitude was set) is, in my opinion, a bit misleading, because gives the pilot the false information that the drone can go up when it cannot do it because the altitude limit has been reached. Anyway ... lesson learned ) |
