JJB*
Flight distance : 12260774 ft
Hi,
At start your battery cells shows already low values, see my chart of your flightlog.
In normal flight cell values always > 3.3 volt.
As you can see in the chart, cells dropped quickly to very low values.
When 1 or more cells really get low ( at 39.5s in flight cell at 2.717 !) than the sofware calls for an critical low autolanding.
Hopefully to land the craft before dropping down while in flight.
Battery wich are not used for some time can show this....
Best practise is to check batt cell values before a flight.
So check this before the next flight(s), and stay close to HP, check regular in this test flight the cell values.
Normal is 100% = approx 4.2 volts.
If your batterry does not show a linear drop from apprix 4.2 - 3.4, 100% to 20% ; battery life is over....
In the small chart typical cell values for a MAVIC2
cheers
JJB [ Chart by FRAP ; the 'best' software for flightlog analysis ]
