Mobilehomer
Flight distance : 18135846 ft
sduck Posted at 4-20 07:18
Another thing to consider trying is not using RTH. I never use it, unless it starts automatically because of some connection interference, and even then I disable it as soon as a connection is re-established. Flying home and landing the drone manually should be something you learn, it's a pretty basic skill, and not hard at all.
You miss the point. Either he is not following proper procedure or something is wrong with the drone. It is an advertised function and should work as stated. Just because you don't use it doesn't mean others shouldn't. If your new car has a backup camera that doesn't work, even though you never use it, would you want it fixed? |
