Wow for $16k and you cant even use the I3 out of the box. You have to drop an additional $1200+tax for a lens. But hey at least they give you a lens box with the drone to put it in after you buy it. 28min flight time which is only about 5min more than the I2. I expected a much bigger jump. Ill stick with my M3 and M3C.
If you buy professional level cameras they are body only, particularly video cameras. Usually the manufacturer doesn’t even make lenses. This is the market that the Inspire is aimed at, and to even include a lens as standard is making unwarranted assumptions as to how the drone will be used.
