Jumper17
Mexico
O3, G2, RC2 all in last firmware and used manual and auto channels. I got RXloss like 4-5 times and no more than 130m away from me, even 10m in front of me. Contacted by email and got the same response
- 'According to the logs, the error message rxloss has not persisted. The analysis requires accurate test time and corresponding goggles screen recording so that we can look at the changes in signal strength, your operations during flight, and surrounding occlusion factors. Based on the current information you provided, the air units might be located behind you, which is out of the coverage range of the remote controller signal, and the remote controller connection signal becomes weak, so the rxloss prompt appears. We would recommend you to try to control the O3 within the area covered by the remote controller directly in front of you, and avoid going behind you or any obstructions between the remote controller and the drone.'
They also asked to send 03 unit for inspection, but as I'm from Mexico, that's difficult.
I can fly the Avata behind a building that is behind me without a problem. I given up on RC2 and will use it only on the Avata. By now I'm thinking of buying the Boxer with ELRS. |
