Sky Biscuit
Flight distance : 1922920 ft
DJI Tony Posted at 4-16 20:41
Hi there. Thanks for reaching out, and apologies for the inconvenience. When the exposure time is too short (less than 1/200 second), or the flight attitude angle is too large (for example, the aircraft is flying in S-mode, or the roll stick is pushed to the end), since the vibration of the aircraft may increase due to aerodynamic reasons, the gimbal may be affected by wind strength, and this can lead to a noticeable dynamic deformation in the video, namely the "rippling effects." Normally, we provide remote solutions and basic troubleshooting like calibrations, increasing the exposure time by using an ND filter or shrinking the lens aperture, reducing the flight attitude angle to get a better picture effect, and ensuring the firmware is the latest. But since the drone has been sent in already, do not worry as our team will be able to determine the cause of it and resolve it. You may also inquire for the assessment result for you to know. We hope this helps clarify some confusion. Please reach us back here should you have other concerns. Have a nice day!
Well, we can rule out flying the drone too fast because I wasn't moving. I 'm not able to check, but I feel the shutter speed would have been quite high as it was a bright day with snow, but maybe not. Thank you for the recommendations! I should have looked into this before sending it in I guess. I just assumed it was broken. |
