JJB*
Flight distance : 12225059 ft
Hi,
Recently a remote pilot experienced a fast autolanding in a RTH.
Discussions etc....
So i decided to test flight my own MINI3PRO, to get data for normal RTH autolandings.
Plus i autolanded in front and behind a stone wall, see the video for this.
In general about autolanding after RTH (or autolanding if selected on the screen)
- In RTH, flying at 48 meters (RTH height setting at 31), flying towards home ofcourse.
- Above HP descend starts with rate of descend at 3 m/s.
- At 20 meters baro height down speed from 3 to 1, 1 m/s at Infra Red sensor height (IRH) of approx 3 meter, followed by further slowing down.
- At 2 IRH down speed 0.1 m/s.
- At this point the cam (if pitch down) will return to zero pitch angle; for 90 down to 0 ; in almost 1 second.
- Continue last height to touch down with speed of 0.1 m/s. (so last records shows only 0.0 or 0.1)
See my chart of an example flown in this test flight. Large chart is the landing as in the video.
[ colomn with 11!1 most right colums = Infra Red sensor height ]
Tested to autoland near an obstacle (OA on ofcourse), distance drone > object about 20 to 30 cm.
Many time my MINI3PRO and MA2 refused to land, seeing the obstacle an unsafe area prompt on the screen. But both drones did just hover really close to that object.
Few times object was not seen properly (i guess) as the drone did finish the autolanding. (and again not steering away from the object)
cheers
JJB [ Charts by FRAP ; the 'best' software for flightlog analysis ]
