djiuser_SAZShCThOQeM
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Flight distance : 274636 ft
Trinidad and Tobago
DJI Tony Posted at 4-16 21:54
Hi there. Thanks for reaching out. Yes, this is possible. Here's how to adjust the sticks:
1. Turn the remote controller over and lift the rear rubber grip from the inside groove.
2. The screws under the grip can adjust the corresponding stick on the front of the remote controller. Use an H1.5 hex key to adjust the resistance of the stick and recenter the stick vertically. The control resistance increases when the F1 screw is tightened, and the control resistance decreases when the F1 screw is loosened. The re-centering is disabled when the F2 screw is tightened, and the re-centering is enabled when the F2 screw is loosened.
Nice thanks for the reply, I can get the best of both worlds now. |
