DJ DJ
DJI Paladin Posted at 4-24 02:25
Hi DJ. We appreciate your kind response. As you mentioned in your response above, you are asking what are picture control (sharpness and contrast) and Function audio control, that is the reason why I asked you for a screenshot or image of where you get this information to provide you an accurate resolution. Anyways, as you already clarify this and as I understand that this is a feature request, no worries, we will coordinate this to our designated team for attention. Thank you for your valued support and we always appreciate your input. Have a nice day ahead.
Thank you for your information. My apologies, I really misunderstood you (language barrier as I assumed).
So - to specify the request that many others have made before:
We really need a way to adjust the in-camera sharpening. It is way too high at the moment for many use cases and results in flickering when there are very fine structural elements in the picture (twigs, grills or lattice etc.). Same with contrast, that is too high sometimes, especially in backlight sitiations. Switch to d-cinelike and back might do the trick but affects too many other image parameters, too. And results in a complete differnt look that makes color grading in post necessary
Same deal with functional audio control: The information is in the other thread about distorted audio with external mics. The way, gain control is implemented now, ist simply buggy. It does not attenuate the analogue microphone signal itself but just lowers the digitized signal. If that is distorted already, negative gain does not help in any way. It just produces a distorted signal with lower amplitude...
So we need a way to control the external audio dac (or in that case the adc to be more specific - its the same chip most of the time...)
But, if you don't understand the requests itself, it might help, to show it some of your engineers, or escalate it to your supervisor. They should understand at a glance, what the request might comprise.
