Preventative Maintenance Schedule
1683 17 2023-4-20
HD Pilot
Flight distance : 5175010 ft
I have asked this question to the DJI Chat and to DJI Support, and the response to my questions has been less than any answer that made sense.
My question was about preventative service maintenance to keep your drone fly and not have an unexpected failure due to something being worn out causing the drone to drop from the sky and hitting something or someone.
I compared the service to a 3000-mile auto checkup or and aircraft having an annual or 100 hour inspection.
So, with that being said, and trying to be more granular, Is there a recommended time, say a life expectancy on the brushless motors, in hours (motor failure), that would require the drones to be shipped out for an inspection or replacement of the motors and electronic tests so you don’t have an inflight failure that could cause damage to property or injury to people below.
I hope someone here can help with answering this question.
Thank you.
2023-4-20
LV_Forestry
Flight distance : 4726654 ft
Latvia
DJI does not publish the average time between failures of equipment.
From experience, without crashing, following the recommendations given in the two threads below, the first thing that will happen at the end of their life are the batteries at around 300-400 cycles they are starting to have a lot of trouble. Beyond 500 I have never reached but I think it is illusory.
After aesthetic defects can occur. Especially the plastic which tends to age badly. Be careful that the crack is not on a structural element. Either you send in warranty, or you repair yourself.
https://forum.dji.com/forum.php? ... &extra=page%3D1
2023-4-20
HD Pilot
LV_Forestry Posted at 4-20 21:09
Thank  you  LV.
I received the same information from DJI when I made my first inquiries.
I have been trying to keep my drones safe and have have followed those care recommendations.
So "providing we don't beat the drones up and use them recklessly", we don't have a set of service guidelines for the life of the motors or electronics reliability after a certain number of hours of use.
2023-4-20
LV_Forestry
Latvia
HD Pilot Posted at 4-20 21:26
Thank  you  LV.
I change the propellers and the propeller/motor interfaces once a year.  These are small plastic parts that undergo a lot of fatigue.  The rest is not too constrained.
2023-4-20
DAFlys
I flew over 5000km on a Mini 3 Pro and the motors showed no signs of issue,   the only issue I had were the arms joints got wobbly.    Props on average lasted 1200km
2023-4-20
Labroides
Flight distance : 9991457 ft
That's not surprising.
There is no recommended time.
Your drone's motors will probably last 10s of thousands of hours - longer than the drone.
2023-4-20
HD Pilot
DAFlys Posted at 4-20 22:36
Thank you the input. I dont know if distance would a good indicator (IMO) for determining time for service. Running time on the motors and the heating of the system boards has me more concerned to the potential of failure during flight. I wonder what the DJI repair stations are seeing when it comes to service?, damage from flights or breakdowns in components.  ie The drones die due to crashes before they have time to breakdown.
2023-4-21
DowntownRDB
Flight distance : 1722 ft
This article has some pertinent information.
https://www.droneblog.com/drone-life-expectancy/
2023-4-21
HD Pilot
DowntownRDB Posted at 4-21 12:50
Thank you, Checking it out now!
2023-4-21
HD Pilot
That is exactly what I was looking for, thou I was hoping DJI had input on what their products longevity would be.
2023-4-21
HD Pilot
That gives me a good rule of thumb on the DJI drones. Thou still a bit vague, it will give me an idea on when i should be sending the drones in for service.
Thank you
2023-4-21
DowntownRDB
HD Pilot Posted at 4-21 12:58
You're welcome and i hope it helps some.
2023-4-21
DowntownRDB
HD Pilot Posted at 4-21 13:01
I've seen the question asked many times over the years and none of the DJI reps ever gave a straight answer.  Guess there are too many variables involved for them to commit.  I always keep an eye on the props, prop screws, debris in the motors and battery condition and so far it has worked out great for me.
2023-4-21
DowntownRDB
HD Pilot Posted at 4-21 13:09
Thank you
My pleasure.  Hope you have a great weekend.  Keep on flying
2023-4-21
HD Pilot
DowntownRDB Posted at 4-21 13:16
Totally understandable, but if the bench test of a constant running drone in controlled conditions would provide some idea of the longevity of parts, that would at lease provide a baseline that could use to plan a time line on when that drone would need to go in for service.
Again, thank you, that was a good read.
2023-4-21
DAFlys
HD Pilot Posted at 4-21 12:31
That was about 200hours of flight.
2023-4-22
Labroides
HD Pilot Posted at 4-21 13:25
That's completely unnecessary.
These drones run for far longer than you imagine without ever needing to "go in for a service".
2023-4-22
Hi there, we are sorry for any inconvenience. We will forward your feedback to the corresponding team. As for the maintenance schedule of the motor, we've confirmed with the corresponding team that if there is no error message on the app after powering on the drone, it's no need to send it back for replacement.
2023-4-23
