DJI Paladin
Hello, the video saved in the remote controller by using the “Cache video when recording” function is mainly used to quickly preview the lens movement effect at a low definition. If you need to edit or share the video, we recommend that you use the video file in the internal storage or the aircraft microSD card. If you are referring to the DJI RC, you may have a copy of the cache files on this path: SD Card/Android/data/dji.go.v5/files/MediaCaches and from there you can transfer it using your PC to your mobile device. Hope this helps. Thank you for your valued support. |
