gasman-443
Hello,
I've been using DJI terra for mission planning: using 3D reconstruction, we set the spraying lines 10 meters above the obstacles below.
The main problem we've encountered is that over trees this creates a very choppy flight line, which slows down the drone every time there is an elevation change.
I was wondering if there was a way to make smoother flight lines using DJI Terra (for example, it would be great if we could set the minimum and maximum relative height where the drone flies to avoid big changes).
Also, can we raise the speed at which the sparying drone flies from 18 km/h? It's usually possible but with this new flight planning method it is blocekd at 18.
Cheers!
