TheBoy
Flight distance : 28958264 ft
Mobilehomer Posted at 5-3 07:12
Not all close craft will set a warning. Until a collision is possible, according to heading and coordinates, there will be no warning. If you are flying straight south and a manned craft is flying straight north a mile to the east, there will be no warning. If the manned is at 20,000' and straight over head, there will be no warning. In your screenshot, the plane and your drone were not on a collision course. So no warning.
My settings were set yo low, medium and high risk collision. I was flying NW at 70m, the plane was flying SE at 185m, and we were about a mile apart. We were definitely in each other's airspace.
The system is only worthwhile if it can be configured to give an early warning, not when the drone is already embedded in the plane's windscreen.
DJI have already confirmed the RC Pro gives no audible alerts for airsense (why on earth not?), and in my flight logs, no mention of the aircraft, despite us heading towards each other at broadly similar heights. The drone obviously picked up the other aircraft, and showed on map *ONCE* I'd put the map in full screen mode, and I was well inside the blue circle around the manned aircraft.
So, Airsense does not work as described. DJI either need to fix it, or stop installing the feature if it does nothing.
I know it used to work on the RC-N1, so maybe its just an RC Pro thing. Maybe the RC Pro is going the same way as the original SC - unloved, buggy and unmaintained. |
