DJI Gamora
Ranjan Posted at 5-7 00:41
Is OPCode a universal format which Dji has provided for other program to read the correction settings?
As you can see in this screenshot Capture one > select >manufacture profile, it doesn't correct the vignetting at all. Hi, Ranjan. Thank you for patiently waiting. DJI's Opcode is used to calibrate the software reference and will adjust the correction strength according to the actual situation. Whether it is jpeg or dng, the shadow correction strength is adjusted according to the actual shooting situation. Basically, it is completely corrected. At night, the ISO is large. In order to avoid noise amplification, at the same time, it is not easy to see vignetting at night, so the correction strength is weak. Therefore, your material may be due to the shooting scene, and the calibration effect is not obvious.
In addition, the DNG standard was proposed by Adobe, allowing users to use Adobe series of software such as PS and Lightroom to try it out. If you are still not satisfied, you can provide the original material for further checking. |
