DJI Gamora
Hi, FTrindade. Thank you for reaching out. You may interchange the RCs as long as you unbind it from 1 drone and then bind it to the one that you're going to use as this is one of the requirements for the Flyaway Coverage.
To bind the remote controller, the network needs to be connected, and the remote controller and aircraft are connected. Then please refer to the below path to bind the remote controller. The path is:
Profile>Device Management>Value-added service>Bind New Device.
To unbind the remote controller, the network needs to be connected, and the remote controller and aircraft need to be connected. Then please refer to the below path to unbind the remote controller. The path is:
Profile>Device Management>Value-added service>Unbind RC
Hope this helps. Thank you for your support. |
