Swapping controllers
1211 6 2023-5-7
Lieutenant
I purchased my mini 3 pro with the RC controller, but I wouldn't mind having an RC-N1 controller for flexibility.
A couple of questions though :
1/  Does the controller bind to the aircraft or aircraft bind to the controller ? so meaning that if I buy a second hand controller will there be a problem connecting it to my drone ?
2/  Is it easy or a pain to swap from one controller and back again when I need to ?
2023-5-7
DJI Wanda
Hello, there. 1. The binding process requires you to do it manually after receiving the package. 2. You can unbind and rebind it though this path: DJI FLY APP- Profile-  Device Management - Account and Device.
2023-5-7
Lieutenant
DJI Wanda Posted at 5-7 05:44
So does that mean the seller of the controller would need to unbind it before sending it to me ?
2023-5-7
FTrindade
Flight distance : 395456 ft
Portugal
The unbind works.
The binding to the RC-N1, in my case, doesn't.
It says the RC-N1 needs a firmware upgrade.... and then it ALWAYS fails.
I have received several error codes...
0x1103a0090012
0x115000100001
and some others
Loggd in and out of the app.
reinstalled App.
tried in another phone (Samsung S22 Ultra and S8)
Tried via Assistant 2 and nothing...
I'm stuck with old firmware on my RC-N1: V04.11.0200
I think I need V04.14.0400 but cannot find HOW to install it.
Any ideas?
Thanks
2023-5-7
Sean-bumble-bee
Flight distance : 15997 ft
Lieutenant Posted at 5-7 06:02
The original-owner/seller must log into their account/app and unbind the equipment, the app needs to be connected to the internet for the unbinding to register with whatever records it.
The original-owner/seller DOES NOT need the equipment in their possession to do this, i.e the equipment could be in the UK with the seller in Australia.
2023-5-7
Lieutenant
OK Thanks for that.
2023-5-7
DJI Wanda
Hello, sorry for the late response. Basically, the mechanism works as Sean said below. The original seller needs to unbind the account or remote controller so that the next user can use the drone with a new account or new remote controller. Unbinding can be done without the physical drone by hand while the binding process is not.
2023-5-13
