As a matter of fact today is the first day without rain... I'm sure you have seen the news about water flood here in Italy...
This afternoon I'll try after work, bye!
I was having a similar issue with downloading High-Res Grid images off of a M30T, only to find out that that it doesn't work. You need to pull the files directly off of the microSD card from the drone. Have you check the card directly to see if your mapping images are there and intact?
The test was good, I was expecting a map with major routes and some buildings, not the "satellite" version, and that's what I had, simple as that...
Downloaded minutes before fliyng, as soon as the mini 3 pro took off my DJRC switched off wifi and bluetooth and the map was still there, very useful to me...
Ernestosi Posted at 5-23 02:26
Your map does show buildings? Any pictures?
PS
I just got news of the flood... Terrible...
Half of my family is from Sicily and the other half from Bologna and Venezia
The problem that need to be fixed now is adding multiple maps of a larger area which your downloaded maps can be seen so you can add additional map areas without duplicating area or allow for the use of a third party map program for those who fly in areas where there is no Wi-Fi or cellular service
Hi there. Sorry for the late response. Are you still experiencing the issue? If yes have you already tried formatting the SD card or replacing it? Also, Please refer to the recommended SD cards if you're using a DJI RC:
