DJI Gamora
Hi, Sir Jackington. Thank you for reaching out. The color depth of the DJI Mini 3 Pro D-Cinelike color is 10-bit.DJI Mini 3 Pro uses DCG HDR technology, which is different from standard HDR (stack technology). DCG HDR is an HDR technology for CMOS, which can capture details in dark parts without losing details in highlights, thus generating multi-exposure fusion video. This video has a higher dynamic range compared with ordinary video, but the generated file is not standard HDR footage. So after being imported into the color correction software, there are no obvious visual differences between the HDR video of DJI Mini 3 Pro and a high frame rate video with the same specification. You can adjust the exposure curve to see the differences in the dark part details. For the color depth and dynamic range of the DJI Mini 3 Pro camera, please see the details below:
If it is a 12 or 48 MP photo in the format of JPEG, the color depth is 8 bit;
if it is a 12 MP photo with the format of RAW, the color depth is 12 bit;
if it is a 48 MP photo with the format of RAW, the color depth is 10 bit;
if it is a video, the color depth is 8 bit. The color depth of the DJI Mini 3 Pro-D-Cinelike color is 10 bit.
The dynamic range of HDR/RAW is 12.6 f-stops, and that of the others is 10.9 f-stops.
Video gamut: Rec. 709.
* Some mobile devices are not compatible with the 10-bit specification, so the video may not play. It may also freeze or have abnormal colors when played.
