DJI Gamora
Hi, WN1X. Thank you for reaching out. Is there any micro SD card in the RC? A microSD card needs to be inserted to download the offline map in DJI RC, and the downloaded offline map will be saved in the micro SD card. Please make sure that the firmware version is the latest, change different Wi-Fi or hotspots to try, make sure there is an SD card inserted and there is sufficient space, then have a try. If the issue persists, please provide us with the following information:
1. A video showing the issue.
2. Your current location information.
3. RC log and tested time.
Here's how to get the DJI RC Logs:
Tool preparation:
1. Be sure to install DJI Assistant 2 (Consumer Drones Series) on a computer.
2. Use the USB 3.0 Type-C cable
Operating steps:
1. Power on the DJI RC remote controller and connect it to the computer using the USB 3.0 Type-C cable.
2. Launch DJI Assistant 2 (Consumer Drones Series)
3. After DJI Assistant 2 identifies the DJI RC remote controller, click the connected device name icon.
4. Go to the Menu page and select [Log Export] in the left menu. Next, click the data to be exported and select [Save To Local].
5. After selecting the storage path, please wait until the downloading and compression have been completed.
6. Then, send the saved file (format: .DAT) to us.
Please keep us posted. |
