kojabov
Turkey
Replacing camera glass can be a delicate process, but with the right tools and technique, you can get the job done. To remove the old glass, you should consider using a few items that will help you safely detach it without causing any damage.
First, it's important to exercise caution and work slowly to avoid any mishaps. Start by using a heat gun or a hairdryer on low heat to warm up the adhesive around the camera glass. This will soften the glue and make it easier to remove.
Once the adhesive is warmed up, you can gently insert a thin, plastic pry tool or a suction cup near the edges of the glass. Slowly and carefully apply pressure to lift the glass away from the device. It's essential to avoid using excessive force to prevent any potential damage.
If the adhesive is particularly stubborn, you can use a plastic card, such as a credit card or a guitar pick, to slide between the glass and the device's body. This will help to loosen the adhesive further and aid in the removal process.
Remember to be patient and take your time. If you encounter any resistance, stop and reassess your approach. It's better to proceed cautiously than risk damaging your device. |
