Gerry1124
Using 3 satellites will give you a (2 dimension) position, (latitude and longitude) the same as a car gps unit. In a (3 dimension) position, you are trying to find your position within a box. Now you will need 6 satellites to give you the 3 dimension position. latitude, longitude and altitude. It can be done with minimum of 4 satellites, but position of accuracy is not precise, the more satellites you have, the better accuracy to within a couple of feet. DJI programmed into the flight GPS a minimum of 6 for the accuracy. |
