SeehawerB
Flight distance : 5414203 ft
Well, that's exactly what I was contemplating about. The OA3 relies only on the gravity sensor = IMU. And this is not good at all. Other OEMs do that better. And this should be, because mounting Action Cameras fixed on moving objects is a normal use case, it's the main use case. Take a car, or a drone, or a train, or ... think about it, in almost any case the camera does not follow the center of gravity within an external gimbal mount, in every case the camera is mounted fixed on an object, if the object changes the direction like on rails, the image will tilt LIKE A PENDULUM. This is not as this should work. Sorry, DJI. You should also take the image content into account. This would give you the immediate clue that the image must not be tilted.
What the OA3 needs is a stabilisation WITHOUT TILTING. Or even better, a horizontal stabilization THAT TAKES THE HORIZONT AS INPUT VALUE AND NOT THE IMU.
Big fail, DJI. Sorry. |
