fans7ac73174
Flight distance : 385594 ft
To see if it's the camera, the props or the gimbal try the following:
1) Record some footage with the drone sitting on a table. If the footage is wobbly, it's the sensor. Do up / down with the gimbal.
2) Record some footage with drone in your hand, simulate flying through the air with some basic gimbal moves. Props aren't spinning. Legs can even be closed. If you get the wobbly effect, it's the gimbal causing the issue.
Did the drone crash recently or hit an object?
