DomTom91
Flight distance : 170646 ft
DJI Gamora Posted at 5-22 06:17
We apologize for the inconvenience, DomTom91. During testing of the iPadOS 14, the iPad could be connected normally to the DJI Go 4 app. However, when the iPad is updated to iPadOS 15 and higher, the connection may fail. The DJI engineers are currently working on resolving this issue. Currently, if you want to use an iPad to connect to the remote controller, you can use a portable power source. Connect the remote controller to the iPad when charging the remote controller. After a connection prompt appears on the app, remove the remote controller’s charging cable. If you have urgent recording tasks, we recommend that you try an iPad with a system version prior to iPadOS 15 or an Android mobile device to avoid disconnection issues. We apologize for the inconvenience. Thank you for your understanding and support.
Hi,
thanks for your answer.
I don't understand how I can connect the RC to the ipad when I'm charge it because there is only one connector. |
