MS
Flight distance : 54469 ft
1. Can you please add Nightmode when using Video Waypoints?
2. Is it possible shuffle the order of the saved Waypoints around or add a Waypoints at the end, then move it up the list to point number 4, for example?
3. Sometimes, I've noticed a small photo thumbnail showing the scene when the Waypoint was created, just above the numbered points.
When I click a point to edit it, the thumbnails disappear. How can I get the photo thumbnails to show again?
It would make identifying & adjusting a specific point easier, knowing I'm adjusting the correct point.
4. What is the order of the executed commands when creating the points?
Example, if I had 3 Waypoints all in a line, 50 metres apart (flying at 10/s). And I wanted to fly from point 1 to 2, hover for 3 seconds, then take a photo, then fly to point 3.
Do I set point two, to hold and take a photo and the drone would follow that sequence, or would it actually arrive at point 2, take a photo as it's nearly at a complete stop, then hover for 3 second, before flying to point 3?
(hopefully, that makes sense).
5. When taking a photo at a Waypoint, can you add a feature to be able to select bracketing the exposure or taking a Pano etc?
Thank you. |
