Crio
Flight distance : 67713 ft
iFlylikeafridge Posted at 6-18 14:25
Hi Crio. I analyzed your images. As it comes to optics, lenses themselves cannot exhibit soft spots or blur spots just on an isolated area in the middle of the frame. My opinion is that what you actually encounter is rolling shutter effect.
You see, Mavic 3 Pro has a very large and heavy camera module, that vibrates way more than Mavic 3 or Mavic 3 Classic. These factors combined with a large sensor without mechanical shutter can lead to more visible rolling shutter artefacts (due to slower readout speed on large sensors) caused by the vibration of the airframe.
As I told you, to perfectly isolate this issue, start your drone without taking off, and hold it in your hand at 2 meters from a brick wall, as perpendicular as possible. Shoot two exposures, one at F2.8, another at F/5.6 focusing in the middle of the frame and post them here the DNG files (not JPEG!).
Its not a rolling shutter buddy. This is exactly the same spot every time no matter what you will do with the camera setting or the camera itself.
I have exactly the same fuzzy spot in the same place when drone is static or in flight.
This is not a variable issue.
Lenses can have many problems if they are not machined correctly. I cant tell what exactly is the issue here, sensor or the lens but as mentionem milion times in this thread, whatever you will do, blurry area is always there, same place.
Also Im not the only one with exactly same problem and in the same place, only the replacement that I've got has it on the oposite side. hence my thought about the lens inperfection.
