digibud
Flight distance : 7820246 ft
DJI Paladin Posted at 5-21 18:45
Hi there. Thank you for reaching out. When the app prompts that the firmware does not match, it may be because the firmware version of the remote control/intelligent flight battery and other components are inconsistent with the aircraft, which leads to flight restrictions, and the firmware needs to be upgraded to the latest version. Please follow the prompts in the pop-up window to refresh the firmware, or connect to the assistant software to manually refresh the firmware. If there are multiple batteries, every time the aircraft is upgraded, each battery needs to be inserted into the fuselage to upgrade together. We will also coordinate this with our team for attention. Thank you for your understanding and support.
Will do, but previously it actually told us it was a battery that needed to be updated. That was much more informative, hence my confusion with the new update alert. The old alert was better but no big deal. |
