DJI Gamora
Hi, Homeyjay. Thank you for reaching out. You might want to consider the DJI Action 2 Magnetic Ball-Joint Adapter Mount which is compatible with Osmo Action 3. This magnetic mount can be used to stick the camera to smooth, flat surfaces. The adhesive base and ball-joint design allow you to stick the camera to surfaces at different angles to gain unique vantage points. Remove the adhesive base, and attach tripods, extension rods, or other third-party accessories via the 1/4 screw hole. Please check it on this link. Hopefully, other users can provide recommendations about the video light. |
