Sean-bumble-bee
Flight distance : 15997 ft
Because there is no guarantee that the ribbon cable is the only damaged component and, unless you carry a stock of known good components, then, if the ribbon cable does not fix the problem, you are left guessing which component to buy next and try.
Add to that that you then likely start running into having to run python scripts to match gimbal components to the main board and a DIY repair becomes less atractive.
BESIDES WHICH, did you fail to spot that a large protion of the main shell is missing i.e virtually ALL of the nose !!!!!!
So much for '' take a few screws out and replace the ribbon cable'', lol, to replace the shell means a COMPLETE dismantling of the drone and that requires unslodering and resoldering the wiring.
