DubSound
Flight distance : 104459 ft
Make sure to verify the ports in betaflight as well as the UART to which your ELRS is soldered. Additionally, double-check the harness connecting the O3 to the FC. It's possible that you might have connected the ELRS receiver to the same UART that the O3 is intended to use for SBUS, which is meant for compatibility with the DJI FPV Remote 2. If the SBUS cables are still present in the harness and your ELRS is soldered to the same UART, you will likely encounter ongoing issues unless you remove or relocate them to a different UART. |
