Im based in Australia and working on a mine site in care and maintenance. Im trying to find out if the Mavic 3 E and my Terra can be setup to default to GDA94 datum. I have no idea what the default system is, but see see references to WGS 84 which I understand is USA or North America. Ive been using the system 'as is' however recently I was given some 2018 surveyed points to use as GCPs, but they are in GDA94 (eastings and northings) format. Can someone point me in the right direction?
Hi there, sorry for the belated reply. Sorry that the map datum can not be set to GDA94. If you have the GCPs in GDA94, you can import them to DJI Terra, mark and optimize, then do reconstruction. See if this helps.
