wsteeleNYC
DJI Gamora Posted at 6-5 07:05
Hi, Will. Thank you for reaching out. When an Android device is connected to a docking station or a multi-device hub, when it is connected to DJI RC-N1 or other devices, it does not support connecting multiple devices at the same time, not because of DJI's relevant restrictions. Hope this helps.
For this use case technically it's not the ability of the rc-n1 to be connected to multiple devices at the same time, but the fact that the RC-N1 functions as the host device. I have determined that the RC-N1 controller connects to the phone as a host making the phone the device and the host port of the hub/adapter then needs to connect to the controller which the controller being a custom device and chipset would need to support these kind of devices, but even if it did we still would not be able to get the phones display to show up via the hubs dp-alt mode support as the phone must be the host for this to work. So as I see it the peculiar way DJI designed the connectivity to the phone is a barrier to supporting this. By peculiar I just mean different. I'm assuming DJI made this decision based on both the chipset chosen and retaining low latency video output to the phone, a challenge for sure. Since this is clearly not going to be an option, I am now debugging the DJI fly app sideloaded onto the Meta Quest 2 in hopes of finding some kind of solution to get the Fly app to connect with the NC-N1 controller on the Meta Quest. This is probably the most viable option to get to work without the assistance of DJI. If DJI wanted, I am pretty sure they could get it to work on Quest 2, but obviously they want us to spend an extra $1k on their hardware for FPV. My guess is there is either some library that the Meta Quest 2 needs to support or some ADB commands to enable some OS level options or security on the Quest 2 headset as I doubt DJI is actively blocking the Quest 2 headset. I've already found out quite a bit in the regards to this already and I don't think I am that far from discovering why the RC-N1 doesn't work with the Meta Quest 2. The larger challenge will be finding the solution to making them work together without the help of DJI, because clearly the latter isn't going to happen. |
