Sean-bumble-bee
Flight distance : 15997 ft
djiuser_zKR5HFX3a2EC Posted at 5-31 11:43
So if it storage both firmware on the remote. Why does it keep asking to update firmware when i switch. It gets annoying. If its already paired, it should just turn on and connect like normal. But it doesnt. I have to manually update firmware when i want to change drones. I hope they can fix it where it will auto connect to whatever drone you already pair it. Example if i pair it to my mini2, mini3, air 2s, and maivc 3 pro. When i turn on the remote and open dji fly app, all i need to do is turn on the drone and it will auto connect without forcing to manually choose the drone and update firmware.
"Why does it keep asking to update firmware w..."
It's saying "updating" because the message is badly worded and that is quite a common problem when dealing with DJI messages. It might be more accurate to say "changing firmware".
As far as I remember the two drones use different communication protocols and those protocols require different firmware. If you swap between drones that use different communication protocols the controller has to 'reboot' and load the alternative firmware.
The Mavic 3 has the new protocol, your older drones presumably all use the old communication protocol and the same old firmware.
You either learn to live with it or use two controllers, there's no point in getting annoyed about it, that's just the way things are. |
