Suddenly drops out of landscape mode
4475 13 2023-5-31
PoorDadTech
Hey all,
Using my Osmo 6 on a Skype call and the gimbal unexpectedly dropped out of landscape mode twice. I don't believe it was a power loss issue as it went straight to portrait mode with no problem.
Is there a way can get it to STAY in landscape?
Setup:
Osmo 6
iPhone 13 mini (with brace)
TIA
2023-5-31
DJI Gamora
Hi, PoorDadTech. Thank you for reaching out. To properly switch the orientation, please follow the steps below:
1. Power on Osmo Mobile 6 and press the composition button twice to switch between the two orientations. (Recommended)
2. You can also switch between portrait and landscape by rotating the gimbal (roll axis) manually. (Note: Please operate with care to prevent your mobile phone from being damaged).
2023-5-31
PoorDadTech
DJI Gamora Posted at 5-31 17:25
Thank you for the reply, but as I mentioned the issue is with it dropping out from landscape mode. I have no issues switching between modes, it just doesn't hold it in landscape.
2023-6-1
DJI-Osmo-User-1
Do you have power save switched on?
2023-6-1
PoorDadTech
DJI-Osmo-User-1 Posted at 6-1 08:49
Good question, I'm not sure. I looked through the manual and didn't find anything on power saving mode.
2023-6-2
DJI-Osmo-User-1
So from the camera view tap the three dots bottom left, this is on iOS. From the pop up menu touch the bottom icon (4 squares)  set the sleep time to disable.
2023-6-4
DJI Gamora
PoorDadTech Posted at 6-1 04:08
Hi, PoorDadTech. Thank you for your clarification. Can you please provide us a sample video for further checking? Please provide the firnware version as well.
2023-6-5
dpiet80
Hey,
same Problem here.
Using Osmo Mobile 6 with Iphone 13.
When switching to Landscape Mode, it just stops working after approx. 30 seconds.
Please help :-)
2024-8-21
dpiet80
ps.
2024-8-21
dpiet80
Does anyone have an advice for me?
2024-8-25
KurtP
dpiet80 Posted at 8-21 10:10
Hey,
same Problem here.
At the end the system status indicator pulsed green twice indicating the gimbal went into standby mode.
2024-8-25
dpiet80
Hmm, the problem only occurs in landscape mode. If in portrait mode, it works fine all the time. Standby time is set to 10 minutes...
2024-8-25
DJI Diana
Flight distance : 2408 ft
Hey,
same Problem here.
Hi there,
thank you for reaching out.
We apologize for the inconvenience. You may follow our recommendations below regarding this situation.
> Update firmware
> Restart the device and perform gimbal calibration
> Save important files and re-install the app via this link
We thank you for your cooperation.
2024-8-26
KurtP
dpiet80 Posted at 8-25 11:44
Your camera is mounted way off-center.  In portrait mode it doesn't matter, but in landscape mode the motors have to torque the phone to keep it in place and they are overworked.
2024-8-26
