Burt37
Flight distance : 4009 ft
Not sure if I have understood your question, but all decent Lipo battery charger do two jobs.
They charge the pack but they also balance the pack. So for instance the Mavic battery is a S4 5000mha with 8 pin output...
2 pin are the main power positive and negative
1 pin common for the balancer
4 pins one for each of the cell for the balancer
1 pin for the internal eprom data chip (power switch)
So all cells are charged simultaneously and if one cell deviate too much from the other, then the charger stops charging and begin balancing, by lowering the voltage of the higher cells. Once they are all back in line or within specs, the charge starts again... When they reach around 4.2 volts each, your battery is fully charge and ready to go... |
